Re: 1952 super m
Posted by John M on February 26, 2014 at 06:20:02 from (68.115.194.228):
In Reply to: 1952 super m posted by steve1243 on February 25, 2014 at 12:22:48:
Theyll grind a little, never saw one that didnt. 3
and 4 done share anything but the shaft they ride
on, so possibly the shaft is wore there. I think
Iwold start with the front end and go from there.
maybe a tire is out of whack. Is it a constant
shake or does the speed of the shake change with
the gear selection?
