Posted by D Slater on February 26, 2014 at 07:55:31 from (184.14.211.223):
In Reply to: Re: 1949 Farmall M posted by mcgyver44 on February 26, 2014 at 07:31:36:
Should be able to see the problem if you remove the belt pulley gear box. Countershaft or bottom shaft in the transmission has lost a solid drive. look at the front two gears in the transmission. If good see if the constant mesh gear on the lower shaft is turning without the shaft turning. 5th only runs through the top shaft. Others need the bottom shaft to turn.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
