Re: Cub Governor Spring Adjusting Screw
Posted by Larry in WNY on February 26, 2014 at 09:17:30 from (12.145.221.230):
In Reply to: Cub Governor Spring Adjusting Screw posted by KCTractors on February 24, 2014 at 17:42:19:
Assuming you don"t have a fuel problem causing the surging and the governor spring is good, turn the screw in or out until it smooths out. It may take a few adjustments before you find where it needs to be.
Larry
