Posted by D Slater on February 26, 2014 at 10:02:26 from (184.14.211.223):
In Reply to: Re: 1949 Farmall M posted by Nebraska Cowman on February 26, 2014 at 08:26:07:
If I understood his last post the tractor will still go in 5th and the PTO shaft quit driving the hydraulic pump. PTO would still have full power and the tractor wouldn't move in 5th if the bull pinion shaft was broke or the differential gears failing. If the differential gears are failing it may catch enough to go though. Hard to say without being there. One post said the PTO was turning slow compared to the input shaft. But without more info that could be normal since the PTO shaft turns at less than half the engine RPM.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
