Re: Can one identify original source of C-123 engine?
Posted by D Slater on February 26, 2014 at 18:22:40 from (184.14.211.223):
In Reply to: Can one identify original source of C-123 engine? posted by djhammerd on February 26, 2014 at 17:23:31:
Supers with 123 use engine serial numbers with letter prefixes. 100,130 and 200, 230 series tractors don't have 123 engine serial numbers high as your engine number. No way to know for sure what tractor that engine is from or power unit parts. 140 and 240 tractors used that serial range of 123 engines. In another post before I said my answer was from a 59 model 140 or 240 if its from a tractor. Since that serial number was in the second month of the year. Look and see if the engine block has a date code ending with a D or a E.
