Re: Can one identify original source of C-123 engine?
Posted by djhammerd on February 27, 2014 at 05:08:44 from (173.66.69.90):
In Reply to: Can one identify original source of C-123 engine? posted by D Slater on February 27, 2014 at 04:35:27:
D Slater..... This is what you posted when I asked why you thought the motor was manufactured in Feb, 59.....
**** "Because if it came from a tractor with that serial number it was probably from a 140 or 240.
If you look at the engine serial numbers the one for each month is the beginning number. See the month serial numbers 73218 will be between. " ****
I went back and looked at the document you posted for me before. The first time I looked at the document, I obviously had problems reading the text on the left (the row headings are more difficult to read than the numbers with them). I didn't realize that both the chassis serial number and engine serial number were listed (DUH). It's clear to me now.
Thank you very much for staying with me on this discussion.
I think you have nailed my engine for having been manufactured in Feb, 1959.
This post was edited by djhammerd at 05:12:10 02/27/14 2 times.
