Yea a 706 is a great tractor . Gas or diesel , the C263 is ok but the later ones had the C291 Oh yea that really makes a good engine and really perks them up when tuned wright . The big thing with the gassers is Fuel and Oil , ya play the game and they will run a long time . Shift linkage , yea the OEM shifter is not the best designed and depending on what your doing can be a pain in the drain that i will not disagree on . But if you keep the clutch , transmission brake and dump valve in adjustment they shift good. IF you are doing a lot of forward and backwards then the 56-66 shifter is better . The diesel engines are ok the D282 is not tops on my list but when in good condition will get the job done . The D310 is great in good condition , but when they start to go down yor in for big expense , injection pump parts are getting really hard to find and they do not service the thermostat anymore and i do not know if someone has come up with something that will fit . Yes we run two 706 gassers one is a 64 and the other is a 67 . The 64 model has been changed to a C291 with the updated sleeves and piston's along with shell we say a few other upgrades . How does it run , you would have to set your donkey in the seat and drive it to see . I do believe you would be vary impressed . As for the amount of fuel it burns i do not think it is unreasonable as i can mow rake and rake a second time and move bales off 28 acres on one fill up on some pretty nasty hilly ground that on first cutting works the snot out of the 706 on the hay bine . Unless we are doing tillage or chopping or in good weather the go to tractor is the 706 , not the 806 or the 1066 . First think anybody says is get the 706 .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
