Re: farmall200
Posted by mkirsch on February 28, 2014 at 06:48:38 from (65.199.189.6):
In Reply to: farmall200 posted by dewy on February 27, 2014 at 19:34:18:
"which one?"
Maybe both. Probably both.
You gotta hook up the depth control bar on the right side for moldboard plows, and I'd imagine the same is true for the disc plow.
You gotta set up the fast hitch to "float" with moldboard plows, both side-to-side, and up and down. I'd imagine the same is true for the disc plow.
It would be best to find the exact model of the plow and then find an owner's manual for it. Disc plows are not common, and I think fast hitch disk plows for the Farmall 200 are particularly rare.
A fast hitch moldboard plow owner's manual will probably be easier to find, and might give you enough information to get the plow working somewhat well. Something like a C-20 manual, which should be available at "binder books dot com".
