bad ring gear on an M
Posted by Charlie on December 18, 2000 at 17:45:58 from (209.130.139.131):
The starter ring gear on my 43 M has some bad spots and occassionally has problems in those spots. I know how to split the tractor and remove the flywheel. My question is how do I get the old ring gear off the flywheel and the new one on.
Post A Followup
: Re: bad ring gear on an M
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
