Re: farmall200
Posted by Mark Peters on February 28, 2014 at 13:03:53 from (69.131.184.114):
In Reply to: farmall200 posted by dewy on February 27, 2014 at 19:34:18:
I`ve never really tried using my C-20 plow on my Farmall 240. It should work, but the first things you`ll need are the filler plates for the fast hitch sockets on your 240. C-20 plow has small (2 1/2" high) prongs and 240 has large (3" high) prongs. You have to make sure all pins are moved to "float position". I think there`s 5 pins alltogether ,if I remember correctly. One for side to side movement inside the RH socket. Then the 2 pins on sockets so they can pivot. Another pin on underside of the FH cylinder, and finally the pin on the left upright moved to float position. Then you`ll need to level plow side to side with the cranks. Not nearly as nice to adjust the plow on a 240 as with a Super C or 200 fast hitch.
