Re: Smoking/Hard Starting International 454
Posted by JimB2 on February 28, 2014 at 15:28:11 from (99.240.243.222):
In Reply to: Smoking/Hard Starting International 454 posted by dvcochran on February 28, 2014 at 14:44:54:
Hi David, I assume injection pump was moved from old engine block? Was injection pump timing set properly? Your description of problem would indicate two problems:
1) Injection timing too slow
2) Rings are not seated properly.
You need to work those German Diesels hard to seat the rings.
JimB
