Posted by PretendFarmer on February 28, 2014 at 15:28:30 from (70.188.162.137):
In Reply to: Pulling with a W4? posted by Tim in New York on February 27, 2014 at 19:11:55:
I guess I am not clear how a W4 would outpull an H.
If you dont weight up, then I suspect the W4 weighs more.
But in antique pulls, we weight up for particular classes. So there wouldnt be a weight advantage. In fact, the H would have an advantage because of more movable weight.
The W4's first gear is barely slower than the H. I would suspect the two would run out of power just the same.
The H has taller tires. To me, thats an advantage.
Now, you will not want the loaded tires. You want as much movable weight as possible. And for the most part, I think the W4 will shine the most in 4500lbs class on a typical short chain clay track pull.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
