you have to get the spec's and then check them against the tractor. how was the head reworked? smoking at idle or pulling? to seat rings the engine has to be at operating temp and worked hard. this drives the rings outward into the crosshatch cyl. pattern. just overheating it is useless, and may cause more damage than good. you do not want the piston skirts getting scored from no clearance due to expansion. how would I tell or test... do a compression check on it, that pretty much tells the engines condition. then you can look to the fuel side of things. was this qualified personal doing this job? if not then that may be another hair puller.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
