Re: wd9 problems
Posted by Red Mercury on February 28, 2014 at 21:22:08 from (204.112.39.24):
In Reply to: wd9 problems posted by BRIAN GARRETSON on February 28, 2014 at 18:06:21:
I agree that it sounds like something is not letting the starting valves close or all 4 are damaged (not likely).
Instead of using the starter to "test" diesel side compression you can also use the hand crank if you have one. Definitely harder to roll the engine over with the crank when it is on the diesel side. With the crank you can easily tell if the starting valves are closing, resulting in good compression on each cylinder.
