steeel piston rings sectional type piston rings
Posted by Loren in WI on March 01, 2014 at 09:26:26 from (75.121.170.248):
curios if any body has seen or used a multi section compression ring? they have six individual rings in stead of one ring that makes up a compression ring. I have a set and thinking about using them in a T-20 engine.
