Re: 560 valve adjustment.
Posted by rustred on March 02, 2014 at 08:11:58 from (74.214.152.80):
In Reply to: 560 valve adjustment. posted by ziemerj on March 02, 2014 at 08:05:09:
factor spec. is .027 hot, so I give them .029 cold. then when re-torqueing the head after warm up you can check them at .027.
