Re: 300 Utility Hydraulic Pump
Posted by SALTY on March 02, 2014 at 08:28:26 from (71.13.0.190):
In Reply to: 300 Utility Hydraulic Pump posted by SALTY on March 01, 2014 at 14:19:40:
I did install a plug in the pressure port to the front control valve. The priority valve now has a line going around the rear of the block to a T into the valve for the fast hitch and then over to the auxiliary valve. The plug was put in the supply port to the aux valve
