Re: super A steering
Posted by Janicholson on March 02, 2014 at 10:01:24 from (74.60.94.18):
In Reply to: super A steering posted by arkansas red on March 02, 2014 at 08:59:50:
Not as in a screw and jamb nut.
Looseness is found in three places caused by lubricant leaking out.
The ball bearing at the far end of the worm under the cap, can be worn and allowing the shaft to either screw in and out (it should not move in and out of the box), or it allows the worm to be displaced sideways away from the sector gear making slop.
Second is the bearings in the sector/steering shaft (vertical shaft with arm underneath). These wear (especially the top bushing) and allow dramatic slop as the top of the shaft moves when effort is applied.
the third (common) is a bad Keyway in the arm to shaft. These frequently get wallowed out and allow 1/2 turn in the wheel of freeplay.
New bearings and bushings are usually the solution for the first two, and re machining the shaft and arm for a bigger woodruf key is the solution for the last. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
