Re: M Rod Bearings Question
Posted by Lyle on December 18, 2000 at 20:38:54 from (205.238.244.84):
In Reply to: M Rod Bearings Question posted by Willie on December 18, 2000 at 11:37:34:
Willie,If you think the rod bearings were noisy when you last heard the tractor run, you should probaly check the crank, both main and rods with a micrometer to see if they are true. This might save you a lot of time. Good Luck
Post A Followup
: Re: Re: M Rod Bearings Question
