Re: Super MTA shifting trubles
Posted by D Slater on March 03, 2014 at 03:50:58 from (184.14.194.188):
In Reply to: Super MTA shifting trubles posted by burnt-smta on March 03, 2014 at 03:03:05:
You didn't say if the shift lever moves normally to the right and moves forward and rearward normally. Take the shift lever out and manually with a bar line the shift fork notches to the neutral position. Then see if the fork on the left will move both directions with the bar and see if it goes in the 4th or 5th gear. If it works maybe the shifter end needs fixed. If it doesn't shift to the 4th or 5th but you can move the notch back and forth, look in the belt pulley gear box opening to see why its not moving the sliding gear.
Usually when the 4th 5th shift rail is out of the neutral position and the transmission is shifted to another gear you have lockup. So makes me wonder if its just a shift lever out of place, but that's the first place to start.
