Re: H Water Pump packing
Posted by Reinders on March 03, 2014 at 08:35:58 from (216.56.48.99):
In Reply to: Re: H Water Pump packing posted by Nebraska Kirk on March 03, 2014 at 08:15:12:
Thank you very much. I will try tightening first. The only trick now is trying to get a wrench on it. I should be able to, otherwise I'll pull the front end. Thanks again!
