Re: H Water Pump packing
Posted by Dave S. on March 03, 2014 at 08:36:12 from (208.92.171.156):
In Reply to: H Water Pump packing posted by Reinders on March 03, 2014 at 07:43:32:
There are two nuts, water pump bearing nut and the water pump packing nut. There is packing behind the water pump packing nut. You can try tightening the packing nut to see if that will stop the leak. If not back the packing nut out( you might have to remove the water pump driver pin, water pump driver and driver studs) install some more packing and tighten packing nut. Do not over tighten the packing nut, tighten just enough to stop the leak. Can get packing at your IHC dealer or just use packing from a roll.
