Re: 856 / 1256 interchangeable housings?
Posted by CDN 400 on March 03, 2014 at 13:14:25 from (67.58.213.237):
In Reply to: 856 / 1256 interchangeable housings? posted by ND856 on March 03, 2014 at 08:26:47:
ND856 yes it will work but you will have to have everything including the torsion shaft and cat 3 arms as well.Keep in mind there is alot more than just the rockshaft cover.Make sure you get a complete cover with the controls on it. The cover you have is just an empty shell just take it off and head to the scrap pile with it.As I said you need the torsion shaft for the bottom,new bushings for the torsion shaft as well as the O-ring retainers.I have done a couple myself.Its alot easier the first time if you have the donor sitting right beside your other tractor if that is not possible try and find everthing in a tractor you can remove yourself that way you can see how it all goes together.
