Re: Farmall C Axle Brackets
Posted by Brian Schmidt on March 03, 2014 at 15:46:32 from (69.66.237.150):
In Reply to: Re: Farmall C Axle Brackets posted by gene bender on March 03, 2014 at 02:04:11:
The eye bolt broke Gene. It is hanging there by the grace of god.
I will try to find a replacement eye bolt as suggested above.
My fix was going to be to weld a sleeve on the end of the bolt to replace the eye.
