Re: farmall m ignition system
Posted by jasinpa on March 03, 2014 at 16:07:47 from (67.234.166.174):
In Reply to: farmall m ignition system posted by butch49 on March 03, 2014 at 14:05:58:
did it run befor? im pretty sure the hot always hooks to the neg. of coil , pos. to the points ,but i will tell ya the right way for that conversion would be to use a 6-volt coil & a resister block to cut power in , with 12v to the points youll burn them up fast , better keep a spare set on hand
