Re: farmall m ignition system
Posted by John T on March 03, 2014 at 16:17:15 from (70.9.70.249):
In Reply to: farmall m ignition system posted by butch49 on March 03, 2014 at 14:05:58:
A standard coil will still work at either Polarity although its more efficient if used correctly. Must have been a connection or other wiring problem or a ground etc.
With switch on theres voltage with respect to ground on the input of the coil while its 0 on output if points are closed but battery voltage if open assuming coils primary winding is okay.
John T
