Re: farmall m ignition system
Posted by CNKS on March 03, 2014 at 17:04:53 from (216.144.104.128):
In Reply to: Re: farmall m ignition system posted by butch49 on March 03, 2014 at 15:50:13:
Negative grounded battery means the wire to the coil goes to negative and vice versa. As mentioned you probably got a better connection. Connecting the wire to the wrong coil terminal does not cause problems for a while.
