Re: farmall m ignition system
Posted by old on March 03, 2014 at 17:05:50 from (209.86.226.34):
In Reply to: Re: farmall m ignition system posted by butch49 on March 03, 2014 at 15:50:13:
Ah but if you had a simple and common bad connection at the coil you could in fact had no spark before you messed with it but after you got spark because you fixed a bad connection you did not know you had. Does not take much to make a bad connection that will stop spark
