Re: 1086 special tool
Posted by gbs on March 03, 2014 at 18:36:52 from (68.115.212.154):
In Reply to: 1086 special tool posted by gbs on March 02, 2014 at 19:47:41:
I wanted to check the flow and pressure on the mcv pump at times when the engine is throttled down steering assist gets weak but comes back when revved back up,my cover doesn't have the front tap plug, it's on the side toward the fuel tank and according to the manual the orifice has to come out to test it,also need to know how to set the spring tension on the action control valve open center system and stop adjustment bolt for the draft on unloading valve not in the manual,i have the position stop set,one other thing the lift lower speed is fine when loaded and lowered from fully raised to fully down but when lowering in small increments it's too fast can this be adjusted ,lift controls got all the O-rings during rebuild
