If it will not go into the 4/5 position to the right on the lever, the rail for 4/5 might be out of place. Pull the lever and see. (two plugs on the shift tower below the little bell shield and spring on the casting) remove one plug by punching it out or drilling a hole and using a slide hammer. Then punch or push out the pivot pin and pull the stick. If the rail slots are aligned, the issue will need to be looked at by removing the belt pulley drive (or cover plate if no drive) and checking the 4/5 mechanism. Best of luck Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
