Posted by Haas on March 04, 2014 at 10:07:49 from (50.142.111.41):
In Reply to: Farmall A Lo-boy posted by Farmall A Tractor on March 04, 2014 at 09:19:43:
This is the way the Hebard Shop Mules are made. Final drives are rotated forward. However...you can't just rotate the final drives because the bolt holes are not evenly spaced. An adapter plate is required do do it. In the past, I reworked the brakes on a shop mule which required removing the final drives. There is a very nicely machined adapter plate between the transmission and the final drive. It has socket head countersunk cap screws to attach to the transmission housing and tapped holes to accept the final drive bolts in the new position. So if you're going to rotate the final drives on an A, you are looking at quite a bit of machine shop work.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
