Re: Farmall 460 on narrow trailor
Posted by ed3 on March 04, 2014 at 14:13:50 from (198.185.164.128):
In Reply to: Re: Farmall 460 on narrow trailor posted by IAtractorKid on March 04, 2014 at 12:03:30:
Assuming the above it should just squeeze on with the tires rubbing.
BUT
It's an old tractor so you have to assume the bolts are rusted solid. You'll need a torch and big extension bar to even try and loosen them up.
Front end will be an even bigger challenge getting the tie rod ends to move and the front axle tube to slide in.
I'd second the idea of getting someone to transport it for you
Good Luck
