Posted by screwstick on March 04, 2014 at 20:50:28 from (71.219.193.128):
In Reply to: Farmall A Lo-boy posted by Farmall A Tractor on March 04, 2014 at 09:19:43:
A "Lo-Boy" is a tractor that sits lower to the ground. The Farmall Cub came out in '47, but in '55 IH started making two versions, the standard Cub, and a "Lo-Boy" that shared the same basic design, but with 90* rotated final drives and shorter axle on the front, giving the tractor a lower profile.
What the original poster wants to do is take an A and do to it what IH did to the Cub.
Why?... well I can't answer him, but I imagine just because. Like adding an extra seat to a B, or making a tricycle Cub.
This post was edited by screwstick at 20:55:07 03/04/14.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
