Posted by mkirsch on March 05, 2014 at 05:05:40 from (65.199.189.6):
In Reply to: Farmall A Lo-boy posted by Farmall A Tractor on March 04, 2014 at 09:19:43:
One challenge you're going to have to deal with on an A is putting gear lube in and keeping it there. The locations of the fill/level plugs are designed for upright operation.
Turned 90 degrees, one of them will be way at the top, and the other will be way at the bottom. One good fill, one good drain. Neither a good level check.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
