Re: What is this Part For? Agri-Supply New Item
Posted by BillOHIO on March 05, 2014 at 12:40:36 from (68.73.97.109):
In Reply to: Re: What is this Part For? Agri-Supply New Item posted by AG in IN on March 05, 2014 at 11:54:56:
AG, I agree with you that these are probably the spacers that goes thru the sealed bearing on disc on 470 Disc, along with others as you mentioned.
Two most common are 652383R1 FOR 7 1/2" Blade spacing and 472594R1 FOR 9" Blade spacing.
I agree Agri-Supply needs a better description if they expect to sell these.
Bill
