Re: Theoretical pump laws...engines are essentally a pump
Posted by buzzinduzzin on March 05, 2014 at 19:04:29 from (66.220.92.37):
In Reply to: Theoretical pump laws...engines are essentally a pump posted by dennis min on March 05, 2014 at 18:07:13:
most drag increases as the square of the speed so if you have a drag co-effecient of say 2 then double the speed you have 4 times the drag. torque is not the mass at a distance from centerline that is inertia . bore/stroke ratio's & BMEP ( brake mean effective pressure) & alot of other factors influence the torque output of a motor
