Re: modern oil in old tractors
Posted by wayne in mn on March 06, 2014 at 10:34:48 from (64.118.12.118):
In Reply to: modern oil in old tractors posted by jerry 4 on March 06, 2014 at 10:25:39:
Non-detergent is recommended for the Lift-All unless you are using a regular hydraulic oil & do not want to mix the fluid between implements.
30 HD is "High Detergent" oil from the past.
Use any good detergent oil from today; it will be far superior to yester-years oils. Multi-viscosity oils (10-30, 15-40, etc.) will do the job just fine.
