Re: altanater
Posted by Bob M on December 19, 2000 at 07:15:18 from (192.232.119.194):
In Reply to: altanater posted by tiny on December 19, 2000 at 05:27:17:
I modified the existing pulley to make it smaller. Do this by cutting the pulley in half. Chuck it in a lathe make the cut in the bottom center of the pulley groove using a narrow cutoff tool. Then reinstall the pulley on the alternator with a couple of suitable washers set between the two pulley halves. This moves the pulley halves farther apart so the belt runs lower in the groove, thus spinning the alternator faster.
Post A Followup
: Re: Re: altanater
