Re: gasket in oil bath fan pully
Posted by screwstick on March 06, 2014 at 15:01:25 from (71.219.193.128):
In Reply to: gasket in oil bath fan pully posted by wm. Ecccles - Jardine on March 06, 2014 at 11:45:28:
Can't answer for other tractors, but the Cub fan pulley was shipped from the factory with an O-Ring at the rear of the fan reservoir on the shaft, but it was not intended to be replaced when it went bad. It was only for shipping purposes.
