Re: gasket in oil bath fan pully
Posted by Bob on March 06, 2014 at 22:04:59 from (64.255.159.192):
In Reply to: gasket in oil bath fan pully posted by wm. Ecccles - Jardine on March 06, 2014 at 11:45:28:
What are you working with, perhaps an "A" a "B"?
NO shaft seal, for either the "Service Products" or the"Schwitzer-Cummins" fan hub.
(There ARE gaskets or a ring between the stack of parts that make them up, though.)
They used centrifugal force, as well as a spiral groove to "screw" the oil back inward. The oil level is BELOW the bore for the shaft so it doesn"t leak "at rest".
Do you know how to correctly fill and "check" the oil in them?
third party image
Parts breakdown:
http://partstore.caseih.com/us/parts-search.html#epc::mr59091ar229996
