Re: farmall a final drive
Posted by buggsy on March 07, 2014 at 07:58:02 from (198.254.229.69):
In Reply to: farmall a final drive posted by buggsy on March 06, 2014 at 17:56:38:
so i took off the cover at opposite end of the hub removed bolt holding axle in and gave the shaft a smack with mini sledge and voila it turns, maybe a little tight in new bearings or something all good now, thanks for the responses
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
