Re: Which Distributor is Correct in These Photos
Posted by Jim Becker on March 08, 2014 at 08:47:47 from (173.71.58.166):
In Reply to: Which Distributor is Correct in These Photos posted by C. Amick on March 08, 2014 at 07:26:09:
Yes, what Bob and Bob M said, with one little exception. Rotation direction for distributors is defined by looking at the drive end, not the end in your picture. So the one on the left is CCW rotation correct for a C. The one on the right is CW rotation.
Each shaft is stamped with the total advance and rotation direction. Part of that mark can be seen in the distributor on the right. You can see an "8" and part of what has to be an "R". This means 8 degree advance and right (CW) rotation. The 8 degree limit implies it is from a gas start Diesel. You can also identify distributors by a code stamped in the mounting flange. The Diesel distributor will probably be stamped either "C" or "H".
The stamping isn't visible on the distributor on the left. It is probably "30L" (flange code "J").
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
