Re: cheap stuff to load tires
Posted by John A. on March 09, 2014 at 11:08:23 from (64.128.16.238):
In Reply to: cheap stuff to load tires posted by Rat in Can on March 09, 2014 at 10:52:20:
Rat, IMO,... I would not load the tires! Start buying cast iron wts. and don't stop till you have 500lbs on each rear corner! You will have a flat sometime and Liquid in the tires just complicates matters a Lot! in extra cost, and trying to find someone who will pump it off, then fix a tube that has had liquid in it, then pump it back in.
IMO put 3 sets of solids on the outside of the wheel and 2 or more of splits wts. on the inside of the wheel. Hope this helps!
Later,
John A.
