Re: weights vs. loaded rears
Posted by rustyfarmall on March 09, 2014 at 13:00:09 from (208.126.186.41):
In Reply to: weights vs. loaded rears posted by BigTone on March 09, 2014 at 12:41:52:
It will take about 4 of the 145# cast iron weights to equal the liquid ballast in your tires now. Cast iron can be removed if and when you don't need it. Cast iron also remains on the wheel, so if you need to dismount a tire and rim, the job is much easier. The plus side to liquid is that possibly, since it is in the tire, it may be more effective, but that has been argued also. I guess probably the liquid is also less costly than cast iron? I personally will never have liquid ballast in any of my tractors. It is simply too messy.
