Re: 1086 hard starting
Posted by Jim Naden on March 09, 2014 at 14:08:50 from (70.198.69.10):
In Reply to: 1086 hard starting posted by phoy on March 09, 2014 at 12:16:34:
First easy thing to check is the condition of the sleeve seals on the steel lines between the filter base and the charge pump on the injection pump. Could be air ingress after shutdown causing a loss of prime.
