Re: 450 overhaul kits?
Posted by D Slater on March 09, 2014 at 18:06:02 from (184.14.194.188):
In Reply to: 450 overhaul kits? posted by JT's RandR on March 09, 2014 at 17:35:22:
Does the block still have sleeves used with the pistons? If so they may be M&W overbore P&S set. No longer made by that company.
They required boring the block. Also the pistons could be for a stock stroke or a M&W crankshaft with 5.75 stroke. Check with the pulling board for the latest on any replacement. You can have replacements made if desired.
Pistons should have a ID on the side if M&W.
