No photo but clear advice: Run push frame under the tractor to brackets on each rear axle 2"X4" rectangular tube. To keep the plow straight use a bracket on the front bolster that guides a vertical piece of that same tube (only this time it is side ways so it is strong left and right.) a front cross member can be used to allow a meyers or other plow to be mounted and the lift hydraulic cylinder is attached from that front bolster bracket to the cross member. A 12" stroke cylinder with a chain lift type of connection prevents damage to the cylinder if the plow runs up over anything. The plow can only lift till it touches the under side of the axles, but it is reasonable and easy to make. Ours of similar design was on our 350 U and was great. Jim
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
