Re: 656 3-point
Posted by Aces on March 10, 2014 at 17:16:16 from (64.5.67.237):
In Reply to: 656 3-point posted by DV on March 10, 2014 at 16:16:49:
DV If the pump was bad the hitch would lift if you activate the auxiliary valves. I would say you have a bad load valve and does not load the system, when you activate the auxiliary valve the oil can only go to hitch so it must lift.
