Re: super c frontloader
Posted by steve1243 on March 10, 2014 at 18:04:04 from (66.87.114.215):
In Reply to: super c frontloader posted by steve1243 on March 10, 2014 at 15:10:14:
I was thinking of coverting a loader from an 8n. I would be making my own mounts. 2''x4'' square tubing for the bottom part of the frame, under the rear axle and over the front axle mounted permantly. I was hoping it would transfer most of the weight to axles that way and not bell housing bolts etc. Then weld some plates on so i could make the rest of the loader frame removeable. I use the tractor to run hay rake and tedder, so I don't want to deal with a front loader on it all the time. The hydaulics would be coming from a bypass block under the stock hydraulic lines by the rocker shafts.
