Re: Re: Re: 1954 Farmall Super C Tractor?
Posted by Paul Shuler on December 19, 2000 at 14:24:34 from (205.188.192.27):
In Reply to: Re: Re: 1954 Farmall Super C Tractor? posted by Robert Almstrom on December 19, 2000 at 14:10:29:
Another way is to click on "serial numbers" on the side bar to the left of the screen. Your serial number on the Super C will be on a plate on the tool box under the seat on the right hand side.This will tell you what year. While you are at it you can register your new tractor under "tractor registry" also
Post A Followup
: Re: Re: Re: Re: 1954 Farmall Super C Tractor?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
